Old 05-23-2011, 11:50 PM
Drewd Drewd is offline
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
Drill a hole for your throttle to ensure your throttle won't rotate. I pull the pin out of the throttle assembly and then drill a much smaller hole and then screw in a small machine screw. Never had any problem with doing this.
To help secure fuel tanks and chain tensioners, put double sided take on both. You'll never have to worry about either becoming loose after tightening them down.
