Old 05-15-2011, 07:59 PM
mapbike's Avatar
mapbike mapbike is offline
Default Re: Can anyone help/visit with chain derail problem
I run the rag joint set up on all my bike and I've never had any chain issues, it's all about everything being mounted correctly and the alignment being right as well as proper tension, although the tension isn't really that big of an issue if everything is setup right, I have one bike that has almost 1200 miles on it now and the chain has been just hanging very lose on it for months now and it hasn't tried to come off a single time, I dont recommend letting a chain be this lose but I've just been testing it up until now to see how well it would stay put with proper alignment and it is great.
Now.....BloodOfAnAkrobat if I were in your area I would gladly help you solve that chain issue but I'm not and central Texas is a pretty good bike ride from you LOL!
All I can tell you is that if the engine is mounted good and solid to the frame and you dont have the idler/tensioner angled in or out to an extreme it has to be that the sprocket on the rear wheel is way out of alignment with the engine.
How wide is the rear tire and do you have a flat sprocket on the rear or is it the dished one?
If it is a dished sprocket is it installed so that the teeth are farthest from the wheel?
If it is, take it off and turn it around so that the teeth on the sprocket are inward toward the wheel and if it makes the chain rub the rear tire replace it with a 26x1.95 or narrower tire and that might resolve your problem.
I have one bike that has the teeth to the outside and it is fine but on another bike I have I cant install a sprocket that way or it will be seriously out of line with the engine and would cause the same issue you are having.
I wish you the best BloodOfAnAkrobat and hope I suggested something here that might help you.
Originally Posted by jedpr1 View Post
ok blood, go to Pirate cycles and purchase a CB-110 hub adapter if you have a 1 speed bike (coaster brakes) or an occ hub adapter if you have a 15 speed bike, then order the sprocket (size) of your preference. I assure you that you will have no problems with the chain ever again.
