Old 08-19-2008, 10:29 AM
crabdance crabdance is offline
Default Re: have REAL power loss now!
Originally Posted by deacon View Post
It you had an air leak it shouldn't bog down. Still check it can't hurt. With the choke off it should run fine if it doesn't have a leak.
I wonder if you have slack in your throttle cable. did you ever adjust that little thing that looks like a buddist temple on top of the carb. If you don't have any air leaks try adjusting that thing. At that point you are at the end of my very limited amount of engine adjustment knowledge. keep after norman he knows more about these carbs than anyone on here.
I don't know how to adjust that thing that looks like a Buddhist temple. I remember on my old carb I adjusted it and it made a big difference in the way it ran. Maybe I can try that on this one. Can't hurt (I hope).
70cc HT
Moon Dog
