Old 05-03-2011, 06:02 AM
fall_down_stand_up's Avatar
fall_down_stand_up fall_down_stand_up is offline
Default Re: Long trip planned-- advice welcome!
The EZM Qmatic is a 49cc HuaSheng engine with a Qmatic gear box....Go with what you want to,but im telling you,the chinese engine is not a reliable way to go....If you just run the chinese engine at around 20 mph at less at half throttle it will last alot longer,but still the chinese engine will be a real risky way to go,not to mention,if the engine does give out you will have to pedal with the clutch pulled in and draging all the weight and friction of that engine chain....You would need to pull the chain off and just pedal that way....
Dont get me wrong,I love the little chinese engines(they are a blast)to run around town and make short trips on,but not for a long journey....
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
