Old 05-03-2011, 01:38 AM
fall_down_stand_up's Avatar
fall_down_stand_up fall_down_stand_up is offline
Default Re: Long trip planned-- advice welcome!
Originally Posted by ilyasemail View Post
Hello all, this is my second post here after browsing about for a few days.
I am planning a ride all the way up the west coast of the US (San Diego-Vancouver) for a few months from now. I have done almost this exact ride before several times, but never with a motor on my bicycle!!! I have also never put together a motorized bike, and am therefore a noob in this hobby.
I want to start shopping around for a bike for this adventure, and would love to get started taking advantage of all of yours' expertise in this matter with a few basic questions.
1.) The bike must be reliable, because I can't go spending days at a time in the middle of who knows where shopping around for new wheels because the one I have broke or mounting the engine on a new frame because the one I have cracked. SO the question: what should I look for in a frame? Based on reading many posts, I take it road bike wheels are out of the question because they are too flimsy and won't stand up well to consistent pressure from an engine. Are road bike frames out of the question? I was thinking of using a mountain-street hybrid, because these still allow for efficient pedaling (a cruiser is out of the question because it doesn't). What size wheels should I look for? What I want out of it is mostly reliability, but speed and looks would be welcome bonuses. Keep in mind I will be loading about 50lbs worth of supplies via front and rear panniers, and I myself weigh 150lbs.
Also: the road is paved 99% of the way but there are areas where its very cracked/poorly maintained
2.) I have read conflicting things about the cheaper chinese "80cc" engines-- some say they aren't reliable, others don't seem to have problems. I would REALLY like to do this as cheaply as possible, and was considering something like the Jet or the Grubee 66cc/80cc engine kit. This is a nearly 2000 mile, 1 month-long (maybe a bit less) journey; I would hate to be stuck in the middle of nowhere with a non-working engine and few mechanic skills (which I will certainly be learning more of these next months).
Thanks for your input!!!
Well,almost every bike you buy for around 100 to 300 dollors or more will have cheap 14 gauge rims on them and will have to be changed to 12 gauge rims or you will be stuck on the road somewere with broken spokes and bent rims....
Now for the engine,a 66cc HT 2 stroke will never make it on that kind of trip,they just are not that reliable and ment for that kind of use....You will need to buy a EZM Qmatic 4 stroke or a GEBE engine kit with a Robin/Subaru engine or some kit of that sorts....Now the EZM Qmatic kit is 620 dollors and the GEBE kit is 629.00.... You could always buy the 66cc 2 stroke kit,but you will have to buy a couple of extra engines to pull in a trailer behind you just incase one gives out on you and you will have to change it out on the side of the road....
Staton sells a chain drive kit for around 600bucks or so that is supposto be really reliable and that is another option....I dont know if the friction drive kit he sells would be good for a long run like that,but I hear they are good,but slip in the rain....Hope this helps....
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
