Old 08-15-2008, 06:27 AM
Default Re: Anyone have any suggesstions on increasing low end torque? Help me out.
Unless that carb has a mixture screw on it in addtion to the idle speed screw, I'd pass. You can get a K&N or other filter for a lot less than 50 dollars!
Don't waste money on a boost bottle, they are proven to be a scam, or imagined performance booster at best.
You can; optimize your mixture, match your ports to the intake and exhaust, lap your head, remove one of the base gaskets if your bicycle motor came with two installed, cut/drill, or remove your baffle, open up your air filter cover, and balance your wheels.
Also, after break-in, your bike will be smoother and faster.
