Old 04-06-2011, 11:51 AM
DaveC's Avatar
DaveC DaveC is offline
Default Re: gas hi-test or reg
Unless you've done something to increase the compression then no.
What's really needed is gasoline without ethanol. There is no longer a local source here so Trick racing gas is the lowest priced gas without ethanol. The alcohol seperates from the mix and attack the aluminum and gaskets.
