Thread: Rough Midrange
Old 08-12-2008, 11:39 PM
pedalpower's Avatar
pedalpower pedalpower is offline
Default Re: Rough Midrange
be gentle with your breakin period.
have you ported the exhaust pipe?-basically cut the gasket to fit the exhaust port and then taper the exhaust flange to match to gasket opening. my engine completely changed after that
after you start it up-be sure to let it warm up a 1 minute or so.
regularly check the air filter for oil and clogs-I can usually start my bike with no choke (in august anyway) just use choke to stop it.
I've never had this confirmed but make sure the magnet is centered in the magneto coil. who knows-you end up checking everything on your ride eventually but porting is usually the first performance mod after sparkplug/wire upgrade.
El Metodo: La Improvisacion
El Objectivo: Explorar un continente que solo conocen por los libros
El Equipo: La Poderosa
El Che
Let the Solution BE the Revolution
