Old 04-03-2011, 11:14 PM
turtle tedd turtle tedd is offline
Default Re: Welding newbie need advice
This has always been a problem on Mig machines..Replace the feed rollers and the liner...tension adjustment is critical--must be just right..This is the reason the better quality mig machines have both a push roller setup near the spool and a pull roller setup inside the gun...Watch you tips inside the gun..if they start to burn ,change them , they do not last forever, the liner behind the tip will burn and clog up
