Old 03-31-2011, 05:52 PM
mkingsley's Avatar
mkingsley mkingsley is offline
Default Re: Weak-Sauce Acceleration
Yeah, before I let my clutch out I've got momentum. But as you just said I think I may have a leak. I didn't mention that now when I'm riding I'm getting about 7 mph lower than my top speed was previously. Another few strange things about my set up is that my bike fails to idle. I've been adjusting the pin to try and find that sweet spot and no luck.
Is it true that if I completely remove the idle pin while the engine is running it should die? If so, mine doesn't die. I thought that once the pin was removed the engine sucks up so much air that it shuts down. Any input on what could be causing that?
