Old 08-11-2008, 02:35 PM
Default Re: Hi Yall , Newbie From Florida
Originally Posted by NunyaBidness View Post
hey HOMEYYYGG, welcome aboard
there is a ton of info here, and plenty of helpful people too
can you tell what kind of tension the clutch cable has? maybe broken? what's happening when you try to engage the clutch?
we made need a little more info but I'm sure someone can help you out with your problem
good luck and happy motoring
The clutch tension is good, cable is not broken. when i try to engage the clutch it just doesnt engage. going to try adding some lucas gear oil & stop leak to the gear box, see if that helps. also on my bike to engage clutch you pull the clutch lever back, unlike some where the clutch is engaged all the time, and you pull back to disengage it.
