Old 03-14-2011, 04:16 PM
Nougat Nougat is offline
Default Re: Clutch Cable Assembly
Also, since the clutch cable has a removable knarp on the engine end, you can pull the cable out of the housing and cut the housing back - provided the existing housing is extra long. That'll give you more exposed cable at the engine side, and a cleaner cable install. If there's a little metal cap over the end of the cable housing, you can even uncrimp that and recrimp it on the new housing end after you cut.
When asking for advice, you did not specify whether you wanted only good advice.
Get on the member map
