Thread: Sup
Old 03-05-2011, 08:35 PM
devares28 devares28 is offline
Default Re: Sup
I know what i did now i did not have the extra thick spacer on the outiside of the sprocket i only had one on. second the carb was leaking because i just got the throttle working instead of hooking it to the circle flange thing inside the carb one run to home depot should fix the alignment and carb problem. as the sprocket looks straight till you look at it tilted slighted to the way the chain pops of as there is extra spacea and not aligned true!
