Old 02-23-2011, 10:33 AM
camlifter's Avatar
camlifter camlifter is offline
Default Re: Exhaust leak by clutch lever
i'd bet a dollar it's the center case gasket, the out put shaft may or may not have a seal, even if it does it's not made to stop engine pressure from getting out, just the grease on the clutch spring and shaft.
pressure from the crank case is getting into the clutch area and leaking out.
