Old 02-16-2011, 09:43 AM
KCvale KCvale is offline
Default Re: Another newbie first build.
Originally Posted by LS614 View Post
The piston actually would be moving in the engine because it is idling,
Hehehe, thought you meant with the motor off the piston was rattling around ;-}
Note you can get a little more coaster brake performance if you pull off the 18 tooth rear sprocket and put on a 19 or even a 20.
As a bonus it's easier to pedal up to speed put you'll need to do chain work ;-}
KC's Krusiers Builds
