Old 02-10-2011, 03:17 AM
rockabilly dan's Avatar
rockabilly dan rockabilly dan is offline
Default Re: Looks like I need a new bike...
im sure you can work it out, i used an exhaust clamp, D clamp, with a car sway bar rubber in the original slot on the motor to fill the gap, got a steel plate, drilled a couple holes for the studs on the motor to bolt through the plate, then bolted that to the clamp, and clamp to the frame, with a bit of very solid rubber around the frame, think its off a conveyor belt, dont really need it, but i didnt want to damage frame, and its solid as.
