Old 08-05-2008, 10:10 AM
brucemg51 brucemg51 is offline
Default Re: trouble with rear sprocket/chain
Originally Posted by fairracing31 View Post
You could also put a small sheet metal screw to keep the tensioner from twisting.
I did that with the handlebars. I've mounted a set of bars from a 1982 Yamaha motorcycle. No matter how much I tightened the clamp, the bars would still come loose, so I drilled a small hole through the clamp into the bars and inserted a sheet metal screw. It worked!
