Old 02-01-2011, 10:21 PM
heyscuba's Avatar
heyscuba heyscuba is offline
Default Re: A quieter clutch cover plate
would this be ok to do,..?
while covering the inside of my clutch cover plate with flat rubber, I thought (to avoid contact with the flower nut) I'd just make a gasket with the same material to move the plate out the same distance as the thickness of the material I was using,...
anyone think this is bad idea,...?
it's flat stiff rubber but seems to fit and hold well,..
I haven't started the motor or anything yet, snowed in,...
"Don't let your meat loaf,...."
see my bar trick vids at
