Old 01-24-2011, 06:28 PM
kipharley's Avatar
kipharley kipharley is offline
Default Re: throttle handle bracket nub
Originally Posted by 2door View Post
If you don't drill the handlebar, or remove the little 'nub' as you call it, tightening the grip assembly down can cause a bind or worse, a crack in the plastic. The 'nub' is there to prevent the grip from rotating on the bar. Most drill a hole to keep things from moving but I've read a few posts from guys who have had luck just tightening the grip after removing that tedious 'nub. Personally, I drill a 5/32 hole in the handlebar.
I cut the nub off and set the throttle in position.
Then I drill through the housing and handle bar and tap in a 3/32" roll pin or tension pin whichever you prefur.Kip.
