Old 08-03-2008, 07:41 AM
brucemg51 brucemg51 is offline
Default Re: trouble with rear sprocket/chain
Originally Posted by jasonh View Post
Here's one thing I noticed today. If your rear chainstay is angled outwards as it goes back towards the wheel, you may have issues. The tensioner will be at the same angle of the chainstay, and this makes the chain run at an angle across the tensioner wheel. If you adjust it so it's quiet, it takes the chain off the sprocket.
One solution would be to "twist" the bracket. I tried to do it with a couple pair of pliers today but failed. Need to figure out a good way to do it.
What is "rear chainstay"? Is this different from the tensioner? Am I missing something?
