Old 08-01-2008, 03:32 PM
jasonh's Avatar
jasonh jasonh is offline
Default Re: 50cc BGF motor won't rev
Also I guess obviously make sure your throttle cable is properly adjusted, i.e. make sure there is no play in the cable - you twist the throttle and it moves the cable as soon as you start twisting. You can take the little slide out of the carb and check that it moves properly as well.
