Thread: Winter Riding
Old 08-01-2008, 09:18 AM
lennyharp's Avatar
lennyharp lennyharp is offline
Default Re: Winter Riding
From Motorcycle Safety | Winter Bike Riding -- The Safe Way - is this list of considerations that are discussed about winter motorcycle riding. For those of you who do not like to pedal and want to go fast this list is very good. I have dealt with cold riding on a bicycle to about 30 degrees and this is not so relevant for a pedaling rider as they generate their own heat after a few minutes riding. Hands and feet however never get warm from pedaling so need to be warm and wind proofed. I like to ride my motored bike more like a bicycle than a motorcycle and do know if ice were a consideration very much I would use a studded tire front and back so I would not always be picking salt and stone out of my road rash....Well on with the quote from the article....
For your motorcycle:
* You need to get a windshield. Don’t ever think that twenty degree temperatures with severe wind chill factors are enjoyable enough for you to neglect having a windshield.
* Make sure your motorcycle battery could stand the strain of chilly blasts. Keep it charged and you can try to use Battery Tender for this.
* Using the proper oil for your motorcycle is also top priority. The 10w – 40w oil is sufficient enough.
* For those with liquid-cooled bikes, make sure that the reading on the anti-freeze is sufficient for the temperatures you’ll be expecting.
* Make sure your bike has been thoroughly inspected for any mechanical problems before starting your ride.
For yourself:
* Be patient of the use of your protective gears that would restrict your overall movement while riding. Like wearing full-faced helmets and heavy clothing that would prevent free and easy movement.
* Keep yourself posted over weather forecasts and road condition reports over the route you'll be taking. It is a good measure especially for those who will ride a long way from home.
* Cover up your body and eliminate all the places where the cold air can easily enter. Some winter riders wear heavy clothing and use duct tape to seal up openings. But modern fabrics designed to seal out the cold and retain body heat can be more preferable. There’s winter clothing made specifically for motorcyclists. You can even use ski pants.
* Electric vests and electric gloves can also be preferable. These electric gadgets are interconnected with wires that also connect to a thermostat that can be kept in your pocket. One end of the thermostat goes to a dedicated connector that leads to the battery. You’ll find yourself fleecy warm in these gadgets to it has a bulkiness to it.
Your winter riding can be a great adventure. Just make sure that while you’re having fun, you and your motorcycle are also safe and sound.
LennyHarp of Lenny's Bikes & Things
The true value of a man is not judged by what he has, but rather by what he can do without.
"We are what we repeatedly do. Excellence, then, is not an action, but a habit." -- Aristotle
