Old 12-13-2010, 08:58 PM
greggasbike's Avatar
greggasbike greggasbike is offline
Default what is this rubber washer ? and why doesn't the ignition wire fit the plug ?
Ok , so I have attached two pics with this...
pic 1 : What is this little rubber washer ? It looks important , it was just randomly in the box with the Grubee , shyhawk 48cc. Just loose in the box , not in any of the little bags.
pic 2 : The ignition box to spark plug. The plug wire will not fit the plug , it is physically impossible for the end of the plug to go into the housing .... now even if you just let them touch to get spark having the spring give tension, the wire /boot that goes over the plug obviously will not stay on, it would just pop off ? Did I get the wrong size in the kit ?
