Old 12-12-2010, 07:42 AM
solokumba's Avatar
solokumba solokumba is offline
Default Re: Total newb with problems
Originally Posted by WildAlaskan View Post
i know my motor is completly takin apart and sitting in a box i didnt know the clutch plate was suposed to spin freely till i repaired my motor on my bike
so i need to do that to break the stuff loose and lube
It is a great tutorial with pics and all. Basically, if you had the engine mounted and the drive chain on the rear sprocket (with clutch handle pulled), you open up the clutch plate, remove the lock screw and the adjust nut and then place a heavy duty screw driver in between 2 of the posts and apply quite a bit of pressure. Then you will here a "POP". Then the clutch will spin freely.
Where is that link?
I may be slow, but I'm not very accurate.
