Old 07-30-2008, 03:57 PM
stude13 stude13 is offline
Default Re: Need Clutch help!!
hi; lubing the cable helps. your clutch is not disengaging. at the clutch end of cable, loosen the cable stay, be careful, an extra hand helps, pry clutch arm toward center of engine, tighten cable stay. if it is good you will be able to set the button on clutch lever and roll the bike. release the button and the rear wheel will slide. i did this by myself. i put a snap tie around the carb. loosely, slipped a screw driver through the loop and pried the bar back, tightened the tie to hold, then adjusted the cable. let us know if it worked. good luck. mitch
