Old 12-08-2010, 11:19 PM
Nashville Kat's Avatar
Default Re: Need help in changing out the mounting studs.
the only acceptable way- the EASIEST way, AND the way you won't damage the threads is to use the double-nut lockdown method- tighten two bolts AGAINST each other tight at the top of the threads, but make sure both nuts are covering stud thread,
and then using two small wrenches, (10 mm spanners are best)
turn both nuts off together- with a little more pressure on the bottom nut, so it doesn't unlock again-
the studs should turn off- if nuts unlock, try again.
