Old 12-05-2010, 10:59 AM
Quenton Guenther's Avatar
Quenton Guenther Quenton Guenther is offline
Default Re: 4 Stroke EZM Silentdrive Boardtrack Attempt
hi weekend-fun,
Not sure, but I think removing the switch will not stop the motor from firing. The switch actually grounds part of the ignition coil to stop it from firing. I just received one of the HF motors to use as the test motor for the new 2-speed, and removed all the switches, oil sensor, and extra wires. The motor does produce spark with everything removed. When I ground the long black wire [from the coil] the plug doesn't spark.
Have fun,
