Old 11-08-2010, 10:17 AM
biknut's Avatar
biknut biknut is offline
Default Re: Just finished my build- Now some problems
I had a small intake leak where the intake manifold meets the head. It caused the idle to be erratic and sometimes die, and oil would leak onto the fin just under the manifold and run around to the front of the engine.
It was easy to fix with some gasket sealer.
After about 50 to 100 miles you should retorque the head bolts. I did mine 120 inch lbs
