Old 10-31-2010, 01:24 PM
Nougat Nougat is offline
Default Re: First build done but have a question!
Make sure you're opening the choke - lever on the right side of the carb, should be in the down position. Either that, or the clutch cable is not adjusted properly; it should pedal without turning the engine over with the clutch handle pulled. Lastly, could be the idle is set too low. Rev it up standing still and screw the idle screw in a touch. I'm messing with my idle all the time.
In any case, it doesn't sound like a big deal. Welcome!
When asking for advice, you did not specify whether you wanted only good advice.
Get on the member map
