Old 10-20-2010, 02:55 PM
biknut's Avatar
biknut biknut is offline
Default Re: Northwoods Ridgedale Cruiser Build
I been riding all over creation. Gone through over a qt of gas so far. Already had a couple of minor issues.
First I got a flat tire yesterday, thanks to a staple in my best friends driveway. Took me 30 minutes to replace the inner tube. Takes me all day to replace a tire on one of my motorcycles.
Then I noticed my rear wheel had too much play in the rear hub bearings. Took 5 minutes to adjust the bearing end play.
Next it started dying at idle when I came to stop signs. I thought maybe the spark plug might be fouling, but it turned out to just be the idle stop screw loosening up from vibration. This caused me to discover a performance enhancement though, because when I thought the plug was fouling I switched from a NGK B6HS to a BP6HS extended reach plug. This increased the top speed about 2-3 mph, and has mo betta throttle response. Before changing the plug I had noticed it wouldn't quite take full throttle, but now it does.
