Old 10-16-2010, 07:58 AM
curtisfox curtisfox is offline
Default Re: Can a pedal sprocket be used on the motor side?
Originally Posted by silverbear View Post
I figured that and was also thinking about clamping the two together with C clamps to act as a kind of template and drill guide. I would still use a punch and drill a pilot hole.
So, will a pedal sprocket work with #41 chain?
They used to sell a drill bit (maybe ACE ) that has a small pielet point. So you can put it in the hole and it will drill the center first then fallow with the rest.(center point drill?). And you could maybe tape a level bubble on your drill?
As far as the 41 chain its the same pitch as the bike chain just a little wider.
