Old 10-12-2010, 09:46 AM
darkhawk22's Avatar
darkhawk22 darkhawk22 is offline
Default Re: AMF Cruiser for motor project
Motor kit arrived! I rummaged through all the parts and everything seems to be there. I've started mounting the sprocket and so far I'm not having much luck. Using the two rubber rings with sprocket facing toward the spokes doesn't work (too wide) and sprocket mounted with only one rubber ring on back and facing toward the spokes doesn't work (chain won't clear the spokes). Lastly, I'll try the sprocket with one ring facing away from the spokes. Wish me luck. If all else fails I'll order a manic adapter.
