Old 09-26-2010, 09:16 AM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Default Re: how to CHOP a fork
Biggest problem with using a tubing cutter to shorten a head tube is a tubing cutter is going to leave a ridge inside the tube that you're going to have to file flat again.
If you have a tubing cutter you can carefully score a line all the way around the tube then use that as a cutting guide for the hacksaw.
Straight tubes suck, the beauty is in the bend.
