Old 09-10-2010, 09:46 AM
meowy84 meowy84 is offline
Default Re: Should I be worried?
After correcting the flower nut issue that the others mentioned and depending how your pedal clearance is looking when the gear cover is on you could also try a thicker gasket or doubling up on the gaskets for the cover to give a little bit more clearance inside the gear case.
McGyver could fix that with bubble gum.
