Old 09-08-2010, 09:22 AM
Nougat Nougat is offline
Default Re: Should I be worried?
Look on the inside of the cover. The three pins that the clutch plate drives may be grinding against the cover. You can add another gasket for some more clearance, or dremel down the inside of the cover a little.
To get that dust out, I'd spray a little brake cleaner on a rag and wipe it out, rather than spraying the brake cleaner directly in.
