Thread: Need Some Help!
Old 08-29-2010, 08:33 PM
Jim C Jim C is offline
Default Re: Need Some Help!
with the wheel off the bike I cut one (1) fiber disk to fit over the axel. I used a 3/16 drift to aligin one of the bolt holes. instaled a blot and just started the nut. I repeated that for all nine blot holes. Then I used a Kant Twist clamp to hold it all together for tightening. It goes like this sprocket, gasket, wheel, gasket, steel half clamps. You need to center the whole assembly before finial tightening. Getting the clamps to lay flat was really hard to do. Then of course I had to do it all over because I had to reverse the sprocket because the chain hit the tire. It was one of the biggest pain in the asses of the whole build.
Jim C
