Old 08-26-2010, 09:36 AM
killercanuck's Avatar
killercanuck killercanuck is offline
Default Re: too much grease?
Sounds like you need to adjust your flower nut. If it was slipping while engaged, that would be too much grease. Basically you remove the little lock-nut, move the flower-nut a couple of notches with the clutch lever pulled all the way in. I forget which way it'll need to go, have a read through this thread.
Check Norm's 2-Stroke repair center stickies for anim's, teardown and more info on your clutch. So you can see how it all works before you go too far.
Norm's 2 stroke repair center - Bicycle Motor at Motorized Bicycle Forum
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
