Old 08-20-2010, 03:31 PM
ReallyOldGuy ReallyOldGuy is offline
Default Re: Need some basic info.
Thanks Nougat: I did that earlier...there will be a problem with the gas tank, but I found a work-around using somethinglike body putty that will adhere to the metal frame, and by pulling and pushing the cables during the drying time, will allow free movement of the cables after the stuff is about half cured. ..then mount the tank before completely cured. If that does not work, then I can mount the tank behind the seat on the carrier. There are other bugs as well....still thinking about just buying a cheap bike that does not have these problems.
