Old 08-17-2010, 10:31 PM
2door's Avatar
2door 2door is offline
Default Re: Chain Tensioner Slippage Prevention
These aren't motorcycles...they're motorized bicycles. There are many of us who run a tensioner and have no issues with them. Installed and aligned correctly they work. Install them wrong and you have problems. Its that simple. Done right, a tensioner will eliminate some of the problems newbies have with chain alignment and the issues it causes. If the chain is aligned correctly, the tensioner wheel aligned correctly and the chain tension is maintained correctly there is no real advantage to running without a tensioner. No you don't gain power. No, the bike doesn't run smoother. If the tensioner drags and is noisy and causes problems you'd better check your installation. The key words here are, "Installed Correctly".
