Old 08-13-2010, 09:30 PM
ferball's Avatar
ferball ferball is offline
Default Re: A new shift concept for the engineers....
I think that a two tensioner set up would be needed to take up enough slack.
I believe that a smaller jump in sprocket size would help, but Jim is working on a three gear system with a 4 tooth difference between each, a total of 8 teeth, this seems practical and doable, so if I solve the problem for a 6t difference then 8t should be doable with the same set up.
