Old 07-18-2008, 10:00 AM
jburr36's Avatar
jburr36 jburr36 is offline
Default Re: Trials and Tribulations - A Build to Remember
After I did the mod around the engine drive sprocket with the steel bar and JB Weld I've never had a problem with the chain and the rear suspension. It handles very nicely. Also I should note that I did have to cut away part of the chain guard to give clearance for the tire and bend the lip on the rear part of the chain guard to a 45 degree angle to keep it from rubbling against the chain during the vertical movement of the rear suspension. That reduced the noise issue considerably.
