Old 07-29-2010, 05:40 PM
sterno666 sterno666 is offline
Default Re: Ok, I give up. How do you start these things?!
I had a similar problem at first because the install instructions suck. You need to pull the clutch rod that comes off the top of the engine in more than 90 degrees when you lock the clutch handgrips. It needs to be at 90 when the handgrip is out fully.
