thepassionneverdies
I recently bought the 58cc StarFire Gen II 2 Stroke Engine to replace my 48cc Broped motor and I'm having trouble installing the clutch cable. All I ordered was the motor not the kit so I'm wondering if I'm somehow using the wrong cable (using a brake cable). Here's what I've done so far.
I've ran the cable through the right side of the motor and once I get to the clutch arm it goes straight through and there's no way to tighten the cable in place. The clutch arm I had on my Broped you would just feed the cable through then tighten it with a screw. Since I couldn't figure out how to tighten the cable on the default clutch arm I decided to switch out the clutch arms. After that I still can't get the clutch engaged. If you guys need pictures I can get that for you. Any help would be greatly appreciated. Also is there suppose to be a pin in between the clutch gears on the left side?
