Old 07-25-2010, 07:03 PM
stevolandis's Avatar
stevolandis stevolandis is offline
Default Re: Greetings,need help with new motorbike
To fix air leaks, make sure the intake tube is bolted tight, put an o-ring between the carb and intake tube, make sure your carb is assembled right, everything tightened down.
To adjust idle, let the throttle all the way down(if it works yet) and turn the screw on the left side of the carb out a little, that will lower the idle, in will up the idle.
Last night, I lay in bed, looking up at the stars, and I thought to myself, "Where in the world is the ceiling?"
66/80cc Stinger on a Black Huffy.
6-speed shifter kit pulling a trailer.
Everything stock(so far)
