Old 07-24-2010, 04:52 PM
corgi1's Avatar
corgi1 corgi1 is offline
Default Re: 2 stroke 80cc clutch question.
Clutch arm is to operate in one direction,looking down on the motor standing behind it (carb side of the cylinder),,,the clutch arm should be in about the 5:30 o'clock position when the clutch is engaged (released lever at the handle bar),,it rotates toward the oppisite side of the motor(under the carb.) to dis-engage (squeze the clutch lever at the handle bar),,,,,,,,,,,,do not turn the lever the other way ( clock-wise),,,,,,the lever operates in a counter clock-wise direction only
