Old 07-10-2010, 03:16 PM
asianflava asianflava is offline
Default Re: Attn: guys that run 100 to 1
Originally Posted by Kevlarr View Post
Apples and oranges here.
You need whatever amount of oil your car requires, whether it's 4 or 40 qts, for cooling not lubrication. Believe it or not most car's oil pickups are designed to not suck air and keep oil pressure with as little as one qt of oil in the pan.
Awww you beat me to it. Unless it's a 2 stroke car, they are totally different. With a 4 stroke, you don't want to burn oil as it is hopefully kept seperate from the combustion chamber. On a 2 stroke, you want to burn the oil for lubrication; no valves, cams, etc so they can get away with it easier than a 4 stroke.
