ok, just an idea,,,,,If possible I would add another angle at the seat area and aim it about 45 degrees down clearing the rack for use,,also you will want some kind of heat protection for your leg,exhaust wrap ,or make a stand off heat shield ,or both(paint it black with high heat paint)
I think you're gonna burn yourself- other than that it looks quiet- but that's not rubber on the first section surely.
Just how well does copper work? the parts are widely available....
When I messed around with some tuned pipes on the china I was always amazed how much more peaceful and quit they got with the pipe ran to the back. A big plus is all that oil from the exhaust doesn't accumulate all over the bike. Always nice to see folks enjoying the hobby.
In a word, no, it won't be OK.
The exhaust on a 2-stroke is actually part of the intake too.
This animation from SpookyTooth shows you better.
With no expansion chamber blowback of fuel it goes out the tailpipe polluting like crazy, and it cuts your power and mileage drastically.
I suggest you use a real pipe, then just add your mufflers after it.
Just go real wide right after the little expansion chamber exit hole so as not to restrict it too much.
Simple is good....im not going to spend 60 bucks on one. i want simple. about pollution. i could care less!
Simple is good.
All I suggest is that you use the existing pipe, then mount, tweak and add to the end of it all you want.
It is not the most efficient expansion chamber but it does function as at least your 2-stroke version of a 4-strokes exhaust valve via tuned back pressure.
Just attach your final pipe to the little end of the stock pipe is all.
But hey, your bike bud, just trying to help ;-}
You plan on putting the muffler INSIDE a wooden box and carrying gas in there too?!!!???
You're extra muffler on the end is pretty much overkill, I have my muffler in back at the end of an expansion chamber and the intake is louder then the exhaust.
