Old 06-22-2010, 06:14 AM
junked junked is offline
Default Re: Question on Installing a Springer Front End.
If you cut the threaded portion make sure you put the adjuster and locknut on first so that removing them after the cut will help fix the threads. Also, don't forget to account for the thickness of the springer bracket that goes between adjuster nut and locknut.
