Old 06-21-2010, 12:45 AM
Patr1ck Patr1ck is offline
Default Re: Manic Mechanic Hub Adaptor
Originally Posted by worksmanFL View Post
(im doing the same build btw)
Can you add a spacer or gasket or shim ..... something to fill the gap? Would it be nesessary?
Did you use the sprocket in the kit? (9 holes?)
Or did you buy the the sprocket with the 3 holes from pirate too?
Thank you.
The gap? ...between the 2 halves of the adapter at the edges where the bolts go through? No need to fill that gap. I just bolted it up and went. It worked fine all week (33 miles). Yep I used the 3 hole Pirate sprocket as well. Is your hub the 1.530" hub?
