Old 06-20-2010, 08:27 PM
worksmanFL worksmanFL is offline
Default Re: Manic Mechanic Hub Adaptor
(im doing the same build btw)
Can you add a spacer or gasket or shim ..... something to fill the gap? Would it be nesessary?
Did you use the sprocket in the kit? (9 holes?)
Or did you buy the the sprocket with the 3 holes from pirate too?
Thank you.
